KO3AK
Нужен совет разбирающихся в видеокамерах
Подскажите, что из этого будет наиболее оптимальным чтобы поцепить на частный дом?
mage Sensor: 1/3" CMOS OV7910 camera
- System & Pixels: NTSC: 768(H)*494(V)
- Horizontal Resolution: 380 TV Lines
- Lens Diameter: 6mm
- Electronic Shutter: 1/60-1/100,000 seconds
- SNR: more than 48db (AGC off)
- Minimum Illumination: 0 Lux/f1.2 (IR ON)
- Video Output: 1.0Vp-p, 75O
- Video interface: RCA female
- Four channel available monitoring at the same time
- Built-in 4 PIP in screen
- Audio monitoring with microphone in camera
- Support audio & video recording, image capturing
- Camera with 8 LED infrared lamps and 7m night vision distance
- Image sensor: 1/3" Omn Vision CMOS
- Validity Pixel: 628×586(PAL), 510×496(NTSC)
- 380 TVL of horizontal definition
- Rotation angle: Level rotation 270° vertical rotation 90°
- Minimum illumination: 0.2Lux/F1.2; 0Lux/F1.2 (IR on)
- Way of control: Control manually, control by remote controller
- Transmission frequency: ISM 2,400 MHz~2,438 MHz 4CH
- Modulation mode: FM
- Unobstructed effective range: 100m transmission distance without block transmission
- Switch the receiver's channels by remote control
- Camera with 30 LED infrared lamps and 15m night vision distance
- Receiver with 4 channels exchangeable by auto & manual
- 300-500m transmission distance without block
Transmission Frequency ISM 2,400 MHz~2,483 MHz 4CH
Modulation Mode FM
Unobstructed Effective Range 300-500m(Without Block)
Operating Temperature 0'C~ +50'C / +32'C~ +122'C
Storage Temperature -20'C ~ +60'C / -4'C ~ +140'C
Operating Humidity 85%RH
CAMERA TV System PAL NTSC
Validity Pixel 628(H) x 586(V) 510(H) x 492(V)
Image Device 1/3" OmniVision CMOS
Horizontal Definition 380TV Line
Angular Field of View 45° (f=6mm)
Minimum Illumination 0Lux
Scanning Frequency(H) 15.625KHz 15.734KHz
Scanning Frequency(V) 50Hz 60Hz
Power Adapter DC 12V/500mA
Dimension 68x52x105mm
Weight 245g
RECEIVER Receiving Sensitivity =-85dBm
Video Output 1Vp-p@75O,S/N>38dB
Audio Output 10KO/200mVp-p
Dimension 120x99x30mm
Weight 165g
Antenna 50ohm SMA
Intermediate Frequency 480MHz
Frequency Stabilization ± 100MHz
Не считаю себя сильно разбирающимся, но на своем предприятии отвечаю за систему видеонаблюдения (22 камеры и сервер). Вторую брать не стал-бы - явно для использования внутри помещений. Третья - сомневаюсь и не доверяю радиосигналу, картинка может запаздывать и не отражать реальной ситуации: на экране ты видишь, что человек подошел к двери, а на самом деле он уже зашел в эту самую дверь. Остается первая: оптика - средне нормальная, есть ночная инфракрасная подсветка. В зависимости от наружных размеров строения и соотв охранной зоны видеокамеры первого варианта может и хватит, хотя приведеных параметров недостаточно для правильного выбора. Камеры для уличной установки имеют специальные тепловые кожухи (что-бы зимой не потели) и спец герметичное исполнения. Это обязательно оговаривается в характеристиках.
Если интересно мнение скажем профессионала - то в принципе
alex_lys, был прав,единственное замечу только одно - первая камера уже с подогревом.Если интересуют какие то консультации - звони.
