blade2008
ВАЗ 2108 или восьмерочка
<object id="smotriComVideoPlayeru2184619cca8_1328961034.4515_5399" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="640" height="360"><param name="movie" value="http://pics.loadup.ru/player.swf?file=u2184619cca8&bufferTime=3&autoStart=false&str_lang=rus&xmlsource=http%3A%2F%2Fpics.loadup.ru%2Fcskins%2Fblue%2Fskin_color_lightgrayblue.xml&xmldatasource=http%3A%2F%2Fpics.loadup.ru%2Fskin_ng_photofile.xml" /><param name="allowScriptAccess" value="always" /><param name="allowFullScreen" value="true" /><param name="bgcolor" value="#ffffff" /><embed src="http://pics.loadup.ru/player.swf?file=u2184619cca8&bufferTime=3&autoStart=false&str_lang=rus&xmlsource=http%3A%2F%2Fpics.loadup.ru%2Fcskins%2Fblue%2Fskin_color_lightgrayblue.xml&xmldatasource=http%3A%2F%2Fpics.loadup.ru%2Fskin_ng_photofile.xml" quality="high" allowscriptaccess="always" allowfullscreen="true" wmode="opaque" width="640" height="360" type="application/x-shockwave-flash"></embed></object>
<object id="smotriComVideoPlayeru2184650d694_1328964796.2217_8510" classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="640" height="360"><param name="movie" value="http://pics.loadup.ru/player.swf?file=u2184650d694&bufferTime=3&autoStart=false&str_lang=rus&xmlsource=http%3A%2F%2Fpics.loadup.ru%2Fcskins%2Fblue%2Fskin_color_lightgrayblue.xml&xmldatasource=http%3A%2F%2Fpics.loadup.ru%2Fskin_ng_photofile.xml" /><param name="allowScriptAccess" value="always" /><param name="allowFullScreen" value="true" /><param name="bgcolor" value="#ffffff" /><embed src="http://pics.loadup.ru/player.swf?file=u2184650d694&bufferTime=3&autoStart=false&str_lang=rus&xmlsource=http%3A%2F%2Fpics.loadup.ru%2Fcskins%2Fblue%2Fskin_color_lightgrayblue.xml&xmldatasource=http%3A%2F%2Fpics.loadup.ru%2Fskin_ng_photofile.xml" quality="high" allowscriptaccess="always" allowfullscreen="true" wmode="opaque" width="640" height="360" type="application/x-shockwave-flash"></embed></object>
После такого видео захотелось брать лопату и бежать на помощь.:( Всё очень печально.
в общем из нового...поменял капот и поставил сзади заводской пластик под полку...(босятский подгон) осталось насобирать денех и покрасить сие чудо в черный цвет.
давно не писал, немножко обновлю...был заменен глушак на прямопук Carex, то есть на самца:))) так же заменен сток руль на более удобный, какой то немец....
Nomak1989,флейта на болт с гайкой прикручивается, пробовал снимал, заводил...ниче так басит..норм.
Nomak1989,так флейта это заглушка сзади, болт снизу у меня, у тебя по идее так же.
Nomak1989, а ты сфоткай;)
DENIS_BER,незнаю:bk:вроде как родная, натур кожа:bk:а там кто его знает
Nomak1989,просто сзади фоткни, видел еще на других изнутри закручивается флейта
Nomak1989,нашел твой глушак Зображення
Прямоточный глушитель CarEx YFX-0658
- Материал нержавеющая сталь
- Размер:диаметр соединительной трубы - 6,35см
- Диаметр насадки прямотока - 7,5см
- Диаметр бочки - 11,5см. , длина бочки - 31,0см
- Длина прямотока - 53,3см.
:az:
Руль Нарди, классный, жаль только что оплетка походу не родная
Может и не нарди, надо смотреть.
Вобщем тут свирели нет да ?((
Да, в твоем флейты нет. У меня с флейтой но я без нее езжу, она тупо в багажнике лежит.
